ECU Codes help
naladude911
Car: 2001 Infiniti QX4
I took off the passenger kickpanel to check my ECU codes today, and my ECU seems to be different then the ones you described in checking the ECU codes. I cant find any indicator lights or screw to turn. I have a CDM car, is my ECU different?
yodawill2000
Car: 94 Infiniti J30
Did you unmount it ??The light is on the front side.
Facing the front of the car
kbflip02
Car: 1994 Infiniti J30
2006 Infiniti G35x
yodawill2000 wrote:Did you unmount it ??The light is on the front side.
once you unmount it then turn it around and youll see what were talking about
heyhi
i actually had the same problem few days ago . u have to take it out and turn it around. take the harness off with the 10 mil screw then theres 2 more screws holding the ecu and 2 screws on the bracket on the top right u have to take out. if u don't get the bracket off u wont get the ecu out. the ecu should slide right out when u take the bracket off it might be tight but it will come off
naladude911
oy ok. thanks. il do it when i have some time. Im taking it to NISSAN next week for some new oil (I dont have the tools to it myself).
