ECU codes 91 240sx
sc0rp
I'm getting a "12" on it. Any ideas where I should start diaging and changing things out?
NISTECH
air flow meter. check the wiring to it and do a voltage drop test on the ground portion of the circuit any thing over .02v is to high you need to splice on an alternate ground run to your intake manifold.
