ECU code NEED HELP!!!
white98s14
Car: CARS, BOATS, BIKES
:helpOk i pulled two codes from my ECU and I can not seem to find them listed anywhere.
It's code 39 & 75 and they are both not to be found anywhere.
I checked 240sx.org FAQ's and there not there anywhere. I am goping to purchase a FSM soon, but can someone help me out?
its for a 1998 S14 :help
white98s14
From an old thread I found that code 75 is an EVAP leak. What do I look for? Is there a sensor? What is EVAP?
ricebike
2002 Quest
2005 Altima
i'm not an obd II familiar but found this site: has p in front of the codes...
http://www.batauto.com/Nissan/...240sx
I guess its for retrieving codes via scanner... sorry can't help u more.
check for vaccuum lines leading to the charcoal canister for starters...
i guess there is a sensor, from the link: EVAP System Pressure Sensor
i've also heard that a loose gas cap would also trigger a code? in other models, but not sure on the late-model 240's
djtodd
You sure you read the code correctly?
They are not listed in the FSM.
yellow_jacket
Car: 95 240sx
OBDII codes should be four digits long and I believe that they always have a letter in front like a P.
white98s14
yes I read them right.
Your not the first to ask. I have no clue what it is.
white98s14
I have a video to show you the codes, but where can I host it?
white98s14
Nevermind. I am picking up a FSM tomorrow.
white98s14
For future reference.
Code 39 - "EVAP Cannister Vent Control Valve"
Code 75 - ""EVAP Control System (Small Leak) Positive Pressure"
Coutesy of 98 S14 FSM.
