goody90q45 »
https://forums.nicoclub.com/goody90q45-u31761.html
Tue May 06, 2008 2:20 am
Something sounds fishy here.......When you check the CEL codes by turning the screw on the back of the ECU does the CEL stay off for the first few seconds after turning the engine on and then come right back?
When you turn the screw to read the codes it should only be done one time to read the codes and a second time to clear the codes.
If you have a CEL, you should have stored codes. It sounds like you may be turning the screw twice before reading the codes. Instructions in the FSM are a bit hazy. I did the same thing the first time I pulled codes.
