candela »
https://forums.nicoclub.com/candela-u13584.html
Fri May 14, 2004 5:37 pm
82 is the crank position sensor. It only is used to help the ECU diagnose a misfire. The only things that can really be wrong with it with that code is the wiring/harness or teh sensor itself. The sensor is on the trans housing facing the flywheel teeth...
