tru »
https://forums.nicoclub.com/tru-u5137.html
Tue Aug 10, 2004 3:07 pm
that mean 55 and 55 mean NO CODE
here is the trouble code list
The codes are: Possible cause: Symptoms:11 Crank angle sensor circuit Wiring fault(connector), faulty sensor. No or difficult starts, bad idle.12 Mass Air flow meter circuit Wiring fault etc., sensor, ECU No or difficult start, lack of power.13 Engine temperature sensor circuit Wiring fault etc., sensor, ECU Engine stalls, lack of power, low economy14 Vehicle speed sensor circuit Wiring fault etc., sensor, ECU Lack of power, poor idle21 Ignition signal missing in primary coil Wiring fault etc., sensor, ECU No or difficult start, bad idle, misfires31 E.C.U. (E.C.C.S. control unit faulty) Wiring fault, ECU internals ?33* Exhaust gas O2 sensor circuit Wiring fault etc., sensor, ECU lack of power, low economy35* Exhaust gas temperature circuit Wiring fault etc., sensor, Cat/conv lack of power, low economy, dash lamp43 Throttle position sensor circuit Wiring fault etc., sensor, ECU lack of power, low economy, stalling45 Injector leak ? Wiring fault etc., sensor, ECU ?55 No malfunction ( all normal )
more infos can be read herehttp://npclub.com/bb/showthrea...18det
