burnin240sx »
https://forums.nicoclub.com/burnin240sx-u13121.html
Mon May 31, 2004 12:34 pm
I’m getting a code 24 knock sensor or circuit
Can this be caused by bad timing?
Or should I just check the wires and replace the sensor as necessary.
I was concerned when my probe (115hp) was faster then my 240(150hp) so I check for some codes and it's giving me a 34. I’ve cleared it and tried changing the timing but the computer just makes it run at 15 btdc. So now I’m concerned that I can’t time the engine correctly with the ecu throwing this code.
