elwesso »
https://forums.nicoclub.com/elwesso-u5248.html
Wed May 26, 2004 9:41 am
I have a code 32, and its called EGR FUNCTION. There should be a temp sensor where the EGR valve is near the plenum, and if theres little flow, it throws a code..
It can only be 4 things
1. EGR valve2. BPT valve3. EGRC solenoid valve4. Vacuum related problem
How the system works: The EGR valve is hooked onto the plenum, and when the ECU decides its time to initiate the EGR, it sends a message to the EGRC solenoid valve (should be in the front of the engine, a litlte itty bitty thing with hoses on it) to clsoe, and this opens up the vaccuum. The valve is connected to the intake somwhere... WHen the solenoid opens, the vacuum goes through, all the way back to the EGR valve, which lifts, and allows the EGR gasses to come in
Another possibility is that its clogged and needs cleaning......
