ECU Code 25
SR20S14
25 - Idle Air Control Valve Is this bad?....What can I do to fix this problem?
rousie13
Car: 2006 Nissan 350z Track Edition, 1997 Ford F250 4X4
Depending on how long the valve is open, will affect how much air is allowed to flow through it. The FSM says to disconnect the TPS to see if the idle drops, and if it doesn't: disconnect IACV-AAC connector. The positive should be battery voltage when the ignition is the ON position. The TPS should be disconnected during this test. If you have access to the FSM, it gives you step by step how to check it. If not, post back.
SR20S14
I'm sorry to ask this but what is the TPS? Sorry I know only alittle about somethings haha i'm learning though....I dont have access to the FSM, Anybody on here know where to find one to download
rousie13
The TPS is the throttle position sensor. I'll see if I can find a picture in the FSM of where it is. But its the connector thats above the throttle body.
rousie13
Post your email, I'll email you the part of the FSM that describes this.
SR20S14
aight thanks..Its [email protected]
rousie13
I tried emailing it to you, but hotmail wont' let me email it to you(too big) and my other email isn't set up for at home. I'm sorry, let me know if you know of another wayt to get it to you.
