Ecu code 21 and no spark
KenATT1
I recently purchased an '89 240sx manual transmission. The clutch fan flew off into the wiring harness for the ignition system with the previous owner. It was cut completely through. I have spliced the wires back together and matched them up correctly according to a wiring diagram i found on the Internet. I also replaced the following parts:
DistributorECUCoilPower Transistor (ignition control module) - swapped from other 240sx that i own that is runningSpark plugs and wiresrotor buttondistributor capResistor 2.2k ohms(orange) and black piece (condenser?) - swapped both - I know resistor tested good at 2.2k ohmsBattery
After going through all these parts i still get no spark and the ecu gives me code 21 (both ecu's do). I do smell fuel when i try to crank the car and it does turn over but gets no spark. The spark plugs are getting wet from the fuel so the injectors are working correctly. I have checked all the fuses in the fuse box. I do notice something that is strange, when i turn the key to ACC when i am about to crank the car the speedometer jumps to 35 mph???
Any suggestions on how to get the car to spark the engine?
Kenny[email protected]
KenATT1
I have also checked the timing for the CAS (crank angle sensor) and i believe it is correct. When i feel compression from cylinder #1 the rotor button is pointing at #1 on the distributor cap.
Kenny
NISTECH
your no start problem is because the ecm is not getting a signal from the distributor to fire the coil(the code 21).I think its possible you incorrectly wired the cut wires. you are going to have to go through them throughly to fing the source of your problem. but the ecm is telling you it does not see a signal from the crank angle sensor or the coil.
KenATT1
I have all the wires color matched correctly. Is there any kind of specific voltage or ohms i am suppose to get through those wires.Wire colors: Green/black, black/red (12v power), yellow/red, grey or white, 2 black with white stripes (ground wires), black, and a couple more i believe.
Kenny
NISTECH
I will pull the diag up on all data today and see what you ign signal wire is and post back tonight.
KenATT1
Have you gotten the diag data yet NISTECH? I am going to work on the car in 30 mins after i get off work i need that information.
Kenny
NISTECH
yea it only shows one black with white tracer wire going to the dist. you claim you have 2?
NISTECH
it only shows 4 wires going to the dist. and 3 going to the coil
KenATT1
4 wires to dist. is right but that is a completly different harness off the distributor. The wires for the coil are 3 they are Red/Black, Black/Silver stripes, and another color. I believe the Black/Silver striped cables are grounds b/c it is grounded to the side of the coil. I have a theory that the wiring may have been stretched/pulled by the clutch fan and somewhere down the line there is a breakage in the wiring (maybe even under the wiring insulation). I need a way to test the lines effectively with a multimeter/voltimeter. What would be the best way to get results, i am thinking that finding the correct pin's off the ecu harness and running up to the wires for the coil and ignition control module?
Do you think this theory is possible? If so do you think i should find a junked 240 and cut the wiring off of it from the back of the intake manifold and re-wire it on this car?
Kenny
NISTECH
I have the wiring diagram laying in front of me and none of the wires you mentioned match the color of wires listed for the coil. The diagram laying in front of me is for a 1989 240sx SOHC KA24E one is for vehicles built before the last six vin numbers of 012039 the other diagram I have is for vehicles built after 012039. the wires between the 2 for those parts is identical. does this car have some sort of engine swap done??
KenATT1
No as far as i know there has not been a swap and i am pretty sure that hasnt been (too much original nissan stuff). Is there anyway i can take pics of the wiring and send them to you or a way you can scan the image of the wiring and show me?
Kenny
NISTECH
yea i can scan the section with the ignition coil and the crank angle sensor that is mounted in your distributor. but be aware the wiring diagram does not show the colors of the wires coming off the component only the wires from the main harness. might this be our confusion here?? you could post a digital pic here on the site through the link in my first post in this thread.
KenATT1
Ok i am about to post a pic of the wires and everything on that page. Hopefully, the pic i took will give you a general idea of what i am dealing with here. I have spent over $350 in parts so far and have worked on the car for over 30 hours in the past 6 days to get the car sparking.
Kenny
KenATT1
http://www.nissaninfiniticlub....t=500
Thats the link. Make sure you fullsize the picture so you can see the wires and their color better.
Kenny
NISTECH
ok in your picture the coil wires,the power transistor(you have it labeled ignition module) the resistor and condensor(you have labeled them incorrectly the black is your resistor) are all wired correctly and match my diag. the wires that you labeled where the cut is do not go to any of those components and I can hardly see what colors those are. if you could move all the other components out of the way and snap a shot of that harness with its connection in the picture I could probably tell weather its right or not.
KenATT1
All of the wires are matched with their corresponding color through the line all the way back. The wires that were cut are the ones i labeled in the picture but farther back in the engine bay exactly where i labled it was cut in the picture. I am thinking about getting a complete wiring harness out of a junked 240. The wires could have been stretched when the clutch fan came off and stretched one of the wires way back in the line and insulation could still be on it but underneath the bare wire is not connected. I wish there was an effective way to test this with a voltimeter or multimeter but, i am not sure how. I believe if you figure out the corresponding ecu wire in that mess in the pic and run a multi/voltimeter on the other end with the ecu harness connector and match it to the exact pin you could test continuity/ohms or something to see if the signal is running completely through the line. I do not know how to do this though and this is why i need the diag and to know which pin's to check on the ecu connector.
Kenny
NISTECH
not a problem kenny I will scan and email it to you. If I post it in members rides I dont know if it will be legable. I will try though first. hang tight I will have it up with in the next 30 mins
NISTECH
KenATT1
I am going to go work on the car tomorrow i will print this diag right now and take it with me. I will get you a better picture tomorrow. I have one other question. I heard that the manufacturers date on the 240sx must coincide with the ECU manufacturers date of the 240 that I got the ECU out of. From my understanding this does not matter, what does matter is if the ECU is from an 89 or 90 and if the car was automatic or 5-speed. The date of the car i have is 1/89 and the ECU i recieved is 2/89. I really dont think it matters but i just want a confirmation from you. Thanks a lot for the diag too.
Kenny
NISTECH
it shouldnt matter that close as long as they are the same vehicle. but the ecu has 2 different wiring diags and it matters by the last 6 numbers of the VIN. see the numbers at the bottom of the drawing? if your last 6 numbers of your vin are lower then that it is for your car now that would mean the car you got the ecm from would have to be the same. as far as the 2 diagrams go the wires for the dist,coil and transistor are the same.
KenATT1
So you mean that the VIN numbers on my ECU need to be lower than the car VIN number or just the fact that the VIN numbers for the ECU and Car must be lower the the last 6 that are on the drawing?
Kenny
NISTECH
no dont worry about any numbers on the ecu. just worry about the vin numbers on both the cars if they are both below 012039 you are good.
KenATT1
The vin numbers on both cars and ecu are higher than the diagram numbers.
NISTECH
ok as long as they are the same you should be ok. the circuits you will be looking at are the same on both diag. so the one I posted will work for your continuity tests.
KenATT1
I ended up fixing the car. I repalaced the whole engine wiring harness with one from a junk yard and replaced the box that resides behind the ecu and as soon as i got it all together the car came alive. Now i have a problem with the car ticking under the valve cover (i think). I have been told it is the hydrolyic valve lifters but i wanna be for sure before i stumble upon this. The ticking doesnt happen until the car goes above 2800 rpm so at idle you do not hear it.
Kenny
NISTECH
lifters are usually the other way around[noisy as hell at idle then disapates at higher rpm] I would be more suspect of chain rattle against front cover somewhere.
KenATT1
What is the best way to resolve this issue rather than replace the timing chain? Or should i even be worried? It is a very annoying sound. On my other 240 i could hear it all the time when i had to replace the timing chain but the sound would only come about when it was warm this car does it when its cold/warm/hot.
Kenny
NISTECH
well you may have a broken guide. take the valve cover off and do a good inspection. shine a flash light down the front cover and look at the entire length of the drivers side guide . Make sure it isnt broken somewhere along its length.
KenATT1
If the guide is damaged i would have the tear the engine apart to replace the guide wouldnt I? Man that would suck or is it even a concern and just drive the car how it is?
Kenny
NISTECH
if the chain blows it will be a whole lot more work then just doing the guide and chain. on your car you can pull just the front cover and replace the chain tensioner guide and all.
