skippysr20 »
https://forums.nicoclub.com/skippysr20-u19627.html
Fri Sep 10, 2004 2:20 pm
last week we got a lot of rain where i live, and i got water in my motor, it started runnin crappy so i shut it off and towed it home, i changed my oil and plugs, drained the gas just in case some was in there too, it was smokin a lil bit of white smoke right after it happened but now it dont, but it idles kinda funny and if i rev it up it pops or backfires a lil bit, so i checked the ecu codes and im getting a code 11- camshaft position sensor, is that what it is makin it pop and idle funny and has anyone had problems with theres before.
btw when i checked the ecu i turned the key to on position, turned the screw all the way clockwise then back and it flashes once then flashes again, the first flash is a lil bit longer than the second one, then it repeats the code over and over till i shut key off, so that means its code 11 right, just checkin
Modified by skippysr20 at 6:25 PM 9/10/2004
