Bring your car to me and I'll have you squared in a New York minute. Tim, you've been at this for a while and you're one of the members that's been around a long time that needs to progress. For all the headaches you've been through, you could've installed an SDS and be done with srewing with your car for a while. Sell the harness and adjourning electronics as well as the afc and use the money towards a down payment on a good standalone, doesn't have to be SDS, but one that's worth your money. Think about and get back with me...............r34 gtr wrote:ive got my car running very rich with my safcII (terrible device by the way, NOT worth the money unless you just want to use a z32 maf or something) and im still knocking like a mofo. zero correction with my 510cc injectors. today (it was 105 degrees, thanks south alabama) and my knock meter read 55. just for an idea it reads 0 when the air temperature is below 80. so i was wondering if anyone knew how much timing control the factory ecu has. it cant be much, otherwise i would think it could pull enough to keep the knock at least sort of low.
on another note, does the power fc do sequential injection? its probably not worth buying as my iacv thingy is dead and it would still run like crap unless i replaced it (freaking $100!! its robbery!), as it uses all the stock sensors and stuff. i was thinking of just blowing all my money on a motec m400 pro so i could use the launch and traction control functions. it would absolutely ruin me financially though. i was going to use the megasquirt, but i have been reluctant because it doesnt yet do full sequential ignition. anyway, ive had enough of my car being near undrivable all the time. ive got to do something. let me know your thoughts
- Tim
Scary it is, but doable as well. Whatever you decide, it's time to toss the factory crapola and move-up in the ranks of performance and flexibility.r34 gtr wrote:ive got $2k coming to me in a few weeks. if thats not enough to cover it i dont know what will. sds sounds pretty good to me but im still checking on a few others. my subaru buddy suggested a hydra, and i might give it a look. dont know of anyone running one on a nissan though. im not that far away, and ive got friends in sarasota that would put me up down there. ill be sure to give you a call first. ive got your number and everything. (scary, isnt it?)
- Tim
Dude, you don't stay that far away! As for installation, it really isn't that hard, but the brackets and magnet placement has to be correct or you will be spending more money. The brackets I have made are from a permanent jig that my aluminum guy has set up for me. I just call with my order and they get made. They aren't too cheap, but in the end, the performance is priceless. No more crank angle sensor, nissan coil packs, no more afm, no more idle control section, no more cold start solenoid, no more headaches. I've been where you guys have been and spent a lot of money along the way and I know when it comes to performance, I won't be using the stock nissan electronics again. Now on my DSM powered hyundai elantra, that's a different story seeing that I reconfigured the stock elantra's harness to accomodate the eclipse's ecu, afm, and I even wired-in the eclipse's injector resistor and it all works perfectly. But nissan, no more.capwred wrote:i know your pain.i have been in the same boat with you.i would love to go with a standalone but i dont know if i can intall it right.i like the sds and would go with that one if i got one.too bad dee you live to far away.ihave been wiothout mine for over a year and cant stand it anymore.
You got mail, dog!Kouks wrote:What just for s&g's, what does an SDS run, and what would it cost to get you to install and tune it? You can email me if youd like, but im genuinely interested.
tcbrandt @ bellsouth dot net
