kouki munster wrote:1. Get a timing light, hook it up, and then turn the dizzy if the timing changed in the wrong direction turn the dizzy the other way.
2. The ecu controls the signal that tells the coil to fire based on the signals it is getting from the cas(most important because this one tells the ecu where the engine is in the combustion cycle) and various other sensors. The ecu doesn't know what the timing is set at mechanically, all the maps in the ecu that determine when to fire the spark plugs are based off the base timing being set at the factory spec. Basically this means that if you advance the timing 1* it will be advanced that same 1* under all conditions, because the ecu doesn't know that you mechanically added 1 more degree of timing by turning the dizzy. The ecu will also only retard the timing below what the ignition maps call for, when it gets a signal from the knock sensor that tells the ecu that there is a high amount of knock, or the sensor itself is determined to be bad by the ecu.
Also look in the fsm for the procedure to set the timing, usualy you have to unplug or jumper something to let the ecu know to lock the timing so it is not adjusting it while you are trying to get it set correctly.
lol well i guess ill just have to find a timing light to get the answer to number 1 since nobody remembers which way they turned theirs when they timed their car. that dosnt bother me
and what you said to 2 makes sense as well, so the ecu sends a signal to the ignition coil and it recieves that pulse for every ignition and then that is sent to the distributor cap center and then when the cap hits it it goes threw the wire to the spark plug, ok that makes sense, so the ignition advances when the rpms rise and i guess a change in pulse to the distributor itself could advance it. also i guess adjusting the base ignition timing also changes the power band a bit dosnt it, since the sweet spot durring the power band will change when the computer advances the timing
and i have read the FSM procedure on setting the timing and i will read it again when i get my hands on one to do the actual thingy
good news so far, swapped ecu to the one that came with the car (but not that engine) and the light has stayed off going to driive it a week to see if it comes on again before i attempt to resmog it to give it time to read any mistakes
thanks for the input on 2 that helps alot, probably a good idea to clean and regap my spark plugs too since they are slightly old and are gapped to the max of the standard range for the ka24de or a little over
