mattdesmond »
https://forums.nicoclub.com/mattdesmond-u16557.html
Mon Jun 07, 2004 12:01 am
Self-diagnostic system can be operated in one of 5 modes.Modes are manually changed using screwdriver through access port onECU. With screwdriver turned fully clockwise, inspection lights willbegin to flash. Count the number of flashes. First flash is mode I,second flash is mode II, etc. When desired mode has been indicated,turn screwdriver fully counterclockwise. In different modes, Red andGreen LED’s perform different functions.
MODE I (MALFUNCTION WARNING)This is the normal vehicle operating mode. Green LED willindicate loop status. If LED is not blinking, vehicle is in open loopor there is a fault with the oxygen sensor or sensor circuit. If LEDis blinking, vehicle is in closed loop. If a malfunction occurs inMode I, Red LED and check engine light (if equipped) will illuminate,indicating an ECCS malfunction has occurred.MODE II (EXHAUST GAS MONITOR)In Mode II, both Red and Green LED’s are used to monitorair/fuel mixture feedback control. Green LED will function the same asin Mode I. In open loop, Red LED will remain on or off along withGreen LED so vehicle must be in closed loop in order for Mode IIresults to be valid. In closed loop, Red LED will indicate if systemis running rich (light off), lean (light on) or if at the idealair/fuel ratio (blinking synchronized with Green LED).MODE III (SELF-DIAGNOSTICS)When Mode III is accessed, codes stored in ECU memory will beflashed by the Green and Red LED’s on the side of the ECU. Red lightwill flash the 10’s column digit, while Green LED will flash the 1’scolumn digit. For example: 3 flashes of the Red LED, followed by 5flashes of the Green LED would indicate a Code 35.MODE IV (SWITCH CHECK)This mode is used for checking ECCS switch status. When theidle switch, starter switch or vehicle speed sensor are activated, theRed LED will come on and go off as the status changes.MODE V (TEST MODE)Mode V represents a real-time diagnostic test of the crankangle sensor, ignition signal, airflow output signal and fuel pump.This mode is accessed for an in-bay running test of the vehicle. TheRed & Green LEDs must be monitored carefully during this test, withspecial attention paid to the number of flashes before each pause.The malfunction code will be displayed only once and willnot be stored in memory. If Red LED blinks on and off evenly, thisindicates a fault in the crank angle sensor. If the Red LED flashestwice before a pause, this indicates a fault in the airflow meter. Ifthe Red LED blinks 3 times before a pause, this indicates a fault inthe fuel pump circuit. If the Red LED blinks 4 times before a pause,this indicates a fault in the ignition signal.ENTERING SELF-DIAGNOSTICSNOTE: When engine is running, it is not possible to switch modes.When ignition switch is turned to OFF position, ECU willswitch back to Mode 1.DUAL LED SYSTEM (5 MODES)1) Turn ignition switch to ON position. Use a screwdriver toturn ECU diagnostic mode selector fully clockwise.2) Wait for inspection lights to begin flashing. At thistime, inspection lights will flash the mode options (i.e. 2 flashesfor Mode II, etc.). As soon as inspection light flashes the desiredmode number (3 flashes for Mode III), immediately turn mode selectoroff.3) If the mode selector is kept in the ON position, the modeselections will continuously cycle (Mode I to Mode II up to Mode V,then cycles to Mode I, etc.) and the process will continue. This willnot erase the memory.RETRIEVING CODESDUAL LED SYSTEM (5 MODES)Trouble codes are read using the Red and Green LED inspectionlights on the side of the ECU. After selecting Mode III, trouble codescorresponding to that mode will start flashing. Trouble codes areindicated by the number of flashes from the ECU Red and Green LEDinspection lights. Count the number of flashes. The Red LED indicatesthe number of tens while the Green LED indicates the number of ones.For example, 3 flashes of the Red LED followed by 2 flashes of theGreen LED would indicate code 32.
