GerryO »
https://forums.nicoclub.com/gerryo-u56567.html
Sat Mar 15, 2008 6:06 pm
OK, so my 1993 J30 has been running really great, until this morning.
It started easily enough, but idlled/ran very rough and the Check Engine light was ON - no blinking codes - just ON constantly, so I didn't even back the car out of the driveway and into the street.
I got gas a Shell station yesterday on the way home from work, so I cleaned-up and re-tightened the gas cap to produce no immediate improvements.
So I disconnected the battery and removed the ECM and the cover from one side - all was bone dry outside and inside and looked good - zero signs of corrosion.
I re-assembled and re-installed the thing to check codes in modes I and II. Mode I shows just the Check Engine light and the red LED ON constantly. Mode II is ZERO from either light at all. No flashing at all.
I disconnected the camshaft/cranshaft position sensor and the engine just cranked and would not start at all. Re-connected and the engine starts, idles rough and with the Check Engine and ECM LED lights still ON.
It's getting dark, so I figure I'll drive it around the block before parking it and coming back to it tomorrow. It starts and runs perfectly, and the Check Engine light is now OFF.
I pull into the driveway and bang on side of the ECM a bit and the engine shuts OFF. I restart the engine and it's still running fine and showing no codes, and bang on the thing again, but this time nothing happens. That's good.
Tomorrow I'll check for any leads on the circuit board that might be able to contact the cover and maybe put thin plastic sheet between the back of the board and the cover, plus I'll put a longer screw in one position that seems to function as a spacer. More to follow.
Any suggestions?
