nguyenmd wrote: ↑Fri Aug 11, 2017 12:05 pm
Please help, I pulled my ecm on 2001 pathfinder, after replace the IACV. Look inside the ecm cover, found burned chip, so def needs a replacement.
Please help as I am dumb and don't know much, but love to work on my car before having no choice but taking it to the dealer. Thanks.
OK, if the ECM was damaged due to a faulty IACV, you DO NOT need to replace the ECM.
Do NOT take it to a dealer and do NOT get sucked into buying either a new one or a rebuilt one. You could easily pay over $1,000.
This is a known problem and has been discussed on here numerous times.
Do a search under IACV replacement, and you'll fine tons of info.
There are several Companies that will repair the ECM for a very reasonable price.
I used Circuit Board Medics:
https://circuitboardmedics.com/nissan-ecm-repairs/
Keep us posted.
