ECM Intake Air Temp sensor??
antbo
it threw my CEL on, on my 97 q45. how do i go about fixing this problem?? is it the harness that connects to that extension part to the air box?? if so the plastic clip on the harness is broke, could it just be moving around?? how else could i diagnose this?
Q451990
http://www.nicoclub.com/FSM/Q45
The '97 file is missing secitons, but the '98 should be basically the same.
Heath
Drake57
Car: 1992 Q45, 1990 Q45 (parts), 06 Sportster XLC, 85 XJ6, 08 4Runner, 89 Suburban 4WD, 75 Honda CT90
If you can find the pins to which the thermistor (sensor) connects and measure the resistance it should be a couple of k depending on air temperature. Cool it with an ice cube or warm it with a hair dryer and it should change.
I had a bad solder joint where sensor connects to pins causing cel with intake air temp sensor code on a Mitsubishi.
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
And please complete your profile with model, model year and trim level, if not standard.
