ECM Engine light Error Code 51
fxgo
I am sorry I met to post this in the Infiniti section. I couldn't delete it so I moved it. If you interested, below is the link.
http://nissaninfiniticlub.com/...66003
fxgo
Hi Q45tech & Boywonder
Problem is fixed! Before bring my car to the dealer, I checked out the the Injector circuitry right up to F40 and F41 connectors. It checked out fine. The only thing I didn't check was the wiring from the engine compartment to the ECM and the ECM itself.
I purchase a used ECM. Just before drive it to the dealer, I installed it. By the time I reached the dealer the problem want away, problem fixed.
Since I was at the dealer, I had them check the car out. The car was running perfectly, no codes. They found a problem with a leaking oil sensor and the variable dash light switch. I had them fix it, check the car out completely, and change the oil.
They did find a small oil leak from the passenger side dome cover. They said it wasn't worth fixing just keep an eye on it or add an oil sealer to the engine.
Should I add an engine oil sealer to the engine or live with it. It looks like it would be difficult to fix. What would you do?
By the way, when I told them that I also was experiencing a battery drain problem and that I though by replaceing the ECM it would fix it. The Dealer said, they experienced the same thing on another car two weeks ago and by replacing the ECM it fixed it too.
Looking at the orignal ECM, it looks like water damage was the culprit. I opened the old ECM. I had corrosion on the circuity.
It was from a small leak on the passenger side winshield. It is not the orginal windshield. I am having it replaced before I put back the ECM. The ECM is on the carpet floor.
It has been a long road. I hope my experience will help another J30 owner. When at the dealer, I like what I saw from all the new Infiniti models. They showed me a picture of the new redesigned M45. It looks really nice and it is faster then the Q45, 200lb lighter.
Thanks again for all your help.
