agne24us »
https://forums.nicoclub.com/agne24us-u9236.html
Thu Aug 07, 2003 1:16 pm
Well for now i may have the problem solved, i found my positive battery terminal with that lovely red connector holding the two wire harness's, was broken at the eyelit. I previously had a Mazda that had the same thing happen and ran like crap, so i got creative and altered the eyelit to resemble a half moon, with the help of my angle grinder and grinding stone, I then reattached the lead and connector. car fired up runs smooth, and for the first time the car now idles at 750rpm. I believe the problem is fixed, but for now i will wait and see. even after trying the code reading again i still came up with code 55 meanig all is well, but i still cant get the O2 sensor test to perform, no flashing lights when at 2000rpm for up to 4 minuets, when the car is at operating temp. it is a new sensor so it likely works, but as long as the car continues to run smoothly i will leave it be.
