ECM code 51 injector circuit?
elrodc123
Car: 1994 Infiniti J30
1999 Infiniti Q45t
my J recently will start vibrating randomly and the check engine light will come on. but when i give it acceleration the car will quit vibrating and the light will go off. i then got to the ECM (pain in the butt), and it gave me code 51 injector circuit. anyone know what this code means?
yodawill2000
Car: 94 Infiniti J30
You have a failing injector.
Ohm each injector and the culprit should show up.
I could be a coil or a plug but, both of my bad injectors did the same thing.
It will get worse and finally fail.
Makes for a shaky ride home. :)
driverdriver
Car: NICO's longtime resident Canuck!!!
A functioning injector will be in the 10-14 ohm range. Anything below or above indicates injector failure.
