Ok I'm chasing down a CEL error 32 (EGR function). Running thru the diag procedure 29 in the fsm, no vacuum to the EGR valve. Manual says to check voltage between ECM terminal 105 (while connected) to ground. I don't see any terminal markings (105 or otherwise) on the ecm connector. Maybe aftermarket ECM?
Anyway I'm going to look over the rest of the vac lines again, but they all seemed good.
Anybody gone thru this before?
