ebrake not working!!
hondah8n
Car: 1995 240sx
just replaced rotors calipers and pads. ebrake is not working. could leaving it in gear hurt it after awhile. any suggestions to fixing this?
240marcuSX
Car: E34 525i
E46 M3
you messed up something on the rear brakes quite obviously, check them. follow the ebrake cable all the way back, and see if its cut or something.
nismofly
Car: 89 Nissan 240SX Hatch
you should always leave it in gear, its the e-brake thats optional
also check and make sure you put everything on right again when you were re assembling the rear brakes
LiU
Car: Cars
make sure you have the ebrak line hooked up (or hooked up right) in the back (both sides)... if it is hooked up right try adjusting tension.
hondah8n
Car: 1995 240sx
it was the tension problem, thanks everyone. its all good now!
