EBC Profec B Spec II Install (Simplified) Need Help!
Blurr
Car: 1990 300zx Twin Turbo JDM Motor Swap
Hey guys,
So I have come across several writeups for install, but it feels like some stuff is getting left out in some of the writeups.
From what I understand, the wastegate actuator hoses need to be run (from the wastegate actuators) and get T'd into the COM port on the EBC Boost Solenoid.
Then the Throttle Body nipples, get T'd and go into the NO Port on the EBC Boost Solenoid.
All the extra nipples, need to be capped off? The ones from the soft accordian pipe, correct?
