EBAY t28 wastegate actuator
Masterdebater
Car: 1989 nissan 240sx coupe
http://cgi.ebay.com/ebaymotors...ZWDVW
so is this the thing u guys were talking about to raise boost a lil bit?
dattodude
Car: CA18DET Datsun 1200 B110 Sedan
yes, a little wastegate preload gives you the ability to raise the boost to what you like. I've set my wastegate to about 18psi using one of these devices on it's own. Dyno guy told me to reduce it to 12 psi, so I did it by winding the shaft out 2mm and I was back to 12psi. The only problem is that it's hard to do while the engine is hot :-)
It's certainly the next thing to do after buying a bleed valve, if you still can't afford an EBC. (I know I can't).
Masterdebater
so u like the performance of it and is it reliable?
float_6969
Note: this is being sold by one of our sponsors. If you go directly to their website via NICO, there might be better pricing.
