Ebay Screamer, unsure of fitment...
TimTurboZ
Car: 95 S14 w/RBXX... 65' Mustang GT
I have read on other ebay screamer pipe listings in the past that they work on s14's I'm just unsure how the pipe will fit (if it will interfere with the steering)
If you own a similar piece or know if it will fit I'd appreciate it. I have the ebay rb motor mount kit (previous owner originally did the 1st swap) the stock elbow barely rubbed my steering and has a hairline opening so I figure I may as well try a screamer pipe because I've always wanted one. Also I can always just buy a new unit or a stock elbow if I dislike the sound so don't hate on the idea :biggrin:
http://www.ebay.com/itm/SKYLINE-GTST-SC ... 1e676c1669
-Tim
ncturbospecv
I have that exact one on my car. S13 with rb25 and mickinny mounts. You have to cut the dump tube at the bend after the o2 bung. It will be pointed directly at the steering shaft. Will this hurt the steering shaft? i dont know, i plan on changing setups soon anyways. Its going to leak out of the dump pipe a little bit. I took off the divider and made a little spacer to take up more room against the housing to reduce the leak as much as possible. The main elbow sits close to the steering shaft but clears it so no denting required. It sounds F'ing awesome though and i dont plan on taking it off till i go topmount. Hope this helps.
TimTurboZ
Thanks For the Reply! I may wait til I have my swap running to order this if I'll have to mess with it but glad to have some feedback
