l0nestar »
https://forums.nicoclub.com/l0nestar-u38221.html
Wed Nov 10, 2010 3:05 pm
The second piece you posted is not a 'screamer' pipe, but a 1 pc dump / downpipe. You are most likely going to run into interference with the steering shaft. (not counting fitment)
Buy an SR downpipe, and modify the ''input' flange (~2.75" iD). It should already have the two bends in it to begin with.
Cut 2-3" below flange then pick up a slip-fit exhaust extension from AZ or O'Reilly. Make sure the rest of your exhaust is installed and bolted up to get the correct angles. Then just tack it up, verify, and then finish the seam weld.
An hour, tops, including mandatory Kaffee und Zigaretten pausen.. if that is your thing.
