Ebay s14 Camber Kit
MIKEL240
Ebay Camber Kit for s14; REAL OR FAKE???All suggestions are WELCOMED!
Check it out:http://cgi.ebay.com/ebaymotors...06318
whiterps13
Car: white LE hatch
link?
MIKEL240
Here is the EBAY LINK...Check out and and tell me what all of you think about it. Thanks
whiterps13
Car: white LE hatch
the minute i see obx i cringe. i dont trust them, and never will. its up to, but on something as important as suspension i would never make a shortcut. tire rack has camber correction bolts. they arent fully adjustable camber plates just to let you know.
WongFeiHung
Cheap and they work...
MIKEL240
Are you sure that they work....do you have it on your car? I don't know if I trust it either. But if you have it on your car than I might get them!
Nismo_Freak
Car: 89 Nissan 240SX
Cam bolts... aka eccentric bolts
Should work fine
WongFeiHung
Yes, I have eccentric bolts for my front struts, work great. I can dial in a decent amount of negative camber, no problems yet...For that price thats a really, really good vaule for a nice and noticeable suspension upgrade...
whiterps13
Car: white LE hatch
look at thishttp://www.nissaninfiniticlub....57593
sil80drifter
Car: 1990 240SX Hatch
FOR THE LOVE OF GOD please tell me how to install them mine came w/out directions and I'm not sure hwo to put them on in the front.
sil80
chmercer
replace the stock bolts with the ones you bought. i dont know what else to say :confused:
sil80drifter
also my pdf version of the FSM has adjustability in the front pictured, as if the eccentric bolts came from the factory.
sil80
chmercer
they do. thoes just have a larger range.
sil80drifter
yeah but there is this funny plate thingy on the bolts, i dunno what to do with it.
like this:http://cgi.ebay.com/ebaymotors...&rd=1
sil80
chmercer
you are probably talking about the lock washer thing. that is on there so when you turn the bolt it will rotate the suspension arm to give you more or less camber, instead of the bolt just unscrewing itself. you have to kindof click it off of the stock bolt. I got mine off with a small flathead screwdriver and pried it away from the bolt. then it will unscrew like normal. if the new bolts you bought do not come with replacment locks, be careful when removing this piece. if they have replacment ones you can just rip it off.
sil80drifter
Hm.... I think I know what you mean. you saw the link, right?
sil80
sil80drifter
ok put the eccentrics in, no oem camber adj bolts there, just normal bolts. the eccentrics were a pain to put in, btu sicne they sent me 4, havign ones' washer ruined left me with a spare one. damn those stock bolts are in tiiiight...anyway adjustability with those eccentrics is not very wide. but good enough i've noticed definite improvement over stock (out of alignment positive) camber. I think i made it all the way negative (~1.5 deg negative). feels pretty good.
sil80
chmercer
u should get an alignment, altering your camber changes your toe.
sil80drifter
mmm.... i get alignment when i get all 4 wheels on (fedex lost one) and get my suspension. for now it's soso but corners well :)
sil80
