1jamesmost wrote:1- u may have to burn off the zinc plating on the surface ??2- which seller/ brand was that (there are some cross drilled Brembos on e-bay)3- forgot what 3 was
Post in the appropriate Infiniti Online Mechanic Forum.chaps007 wrote:so what can we do.
Your choices are OEM, Brembo, PowerStop. Be sure the last two are form reputable sources.chaps007 wrote: i have this issue where the shifter shakes and the car will kind of pulse to stop below 40mph. i replaced the front rotors and brakes assuming that they were warped. i dont know if the back ones are causing this or what. i really want some better braking power. who knows whats good for a Y33 2000 Q45t
Not so fast. Turns out that there was still a slight vibration. I turned the original front rotors, put the original rear rotors back on and was too lazy to index them. Guess what? Back to normal, smooth and easy braking. Sidenote, I was looking at Tirerack YESTERDAY and front Y33 rotors were $30 a piece, TODAY they are $41-should have bought them yesterday!bullittandy wrote:Update- I put the "original" front rotors back on and indexed them to .001. The braking is now butter smooth, even from 90MPH. Interestingly, the worst index with the "original" rotors was .0025 and to get .001 I only had to try three positions. The ebay rotors were at .001 but as bad as .006. This leads me to believe that even though the ebay rotors were set up well, they must have been warped somewhere else. I'm trying to contact rotorworks to see if they'll give me a refund or maybe store credit (91 Mustang where vibrations are a way of life). However, if they won't, would anyone be interested in these rotors. They'd require some work but maybe someone wants to experiment?Y33 [email protected]
nopionline.com has them for $26.46bullittandy wrote:Not so fast. Turns out that there was still a slight vibration. I turned the original front rotors, put the original rear rotors back on and was too lazy to index them. Guess what? Back to normal, smooth and easy braking. Sidenote, I was looking at Tirerack YESTERDAY and front Y33 rotors were $30 a piece, TODAY they are $41-should have bought them yesterday!
