Ebay Radiator
YoungGun
Car: 1992 S13 Coupe
Anyone have experience with this piece?http://cgi.ebay.com/ebaymotors...wItemI mean if my ebay fmic is holding up fine and doing its job it seems a radiator would do the same no?
YoungGun
Car: 1992 S13 Coupe
Also would a single 14" fan be sufficient in keeping the car cool? It gets pretty hot here in the summer 100+ degrees.
efrain240sx
Car: 1992 nissan 240sx HB
they are pretty good, friend has been running one for some time now with no problems. As for the fan it all depends on how many cc of air it flows.
schanne
Car: 93 Hatch-Sr20
I have one just like it. Paid a lil more, but it's worked fine for me.
karmakaze
Car: 98 240sx SE
YoungGun wrote:Also would a single 14" fan be sufficient in keeping the car cool? It gets pretty hot here in the summer 100+ degrees.
i run a single 16"
I-Fenix
Car: 72-70-74 240,260 and 280Zs
ok and cheap intercooler and cheap radiator are totally differnt.. and intercooler is pretty hard to fuk up.. a radiator now.. if the passages are not correct and the flow isnt right it can cause major cooling issues.. also unless you get a real electric setup i wouldnt suggest useing a electric when the clutch fan is just plain and simply optimal. you really dont see that much gain hp and response wise to risk you engine with a cheap electric fan.. as far as a radiator goes..the shop i worked at had als lot of problems with cheap radiators and even with some decent ones.. save your money buy a koyo or a griffin even better. for electric fans i reccomend the flex-a-lite dual setup for the s13 and s14 it attaches to the stock mounts for the shroud. and has a shroud with the fans. just mounting a single setup in the middle of the radiator only cools 60% or less of the coolant as it flows. do yourself a favor get a shrouded one or just stick with stock. its your money in that motor protect it.
TheKon
Car: 2005 Nissan Altima 3.5SE
I plan on using a dual fan setuphttp://www.frsport.com/Flex_A_....htmlbetter safe than sorry...I'm using rods rated for 700hp for my 300hp build. Nothing sucks worse than your car having to come off the road because of something stupid that you could have invested another $100 and not have to worry about it
jblackwell
Car: Several
YoungGun wrote:Anyone have experience with this piece?http://cgi.ebay.com/ebaymotors...wItemI mean if my ebay fmic is holding up fine and doing its job it seems a radiator would do the same no?
I've seen plenty of those running around... They work fine. If you have a thermostatically controlled fan, a GOOD single fan will suffice. There are plenty out there with a nice shroud and built in thermostat if desired.
MastaYu
Car: 92 Nissan 240SX SE HB
they work just fine.
CMG
Car: 1989 240sx Hatch w/ Redtop
Why don't ya buy one and try it out and report back in 6 months. As far as the fan the FAL is nice but at over $200 you could do just as well with the Altima fan. Could be mistaken but I believe popular consensus is that removing the clutch fan and using an electric fan is better.
tiger
i got one generic aluminum radiator ebay 120 bucks.. perfect fitment works perfect.. I mean, why would you waste $ on a koyo? A radiator isn't that hard to manufacture so what makes koyo's so special? The name I guess. But just for you guys' information, ebay aluminum radiators work fine. at least the one I have.
Zenkikid813
Car: s14 with sr20det
yea dude the ebay radiator works just fine i have one with dual flex-a-lites
driftin_sr20det
Car: 92 Coupe
Your paying for the koyo name and about another 1" of thickness. Which is kind of over kill unless you are doing some serious driving.
crashcourse
Car: 92 nissan 240sx-hatch, 95 240sx- coupe
E- bay radiators are fine.I popped a head gasket on a 80 degree morning in traffic and still didnt get hot with one fan(stock)
