ItzGenX »
https://forums.nicoclub.com/itzgenx-u1074.html
Sun Apr 03, 2005 1:36 pm
My cousin actually bought one of those knockoff pans. The baffle plates barely fit. After it is screwed down, you can barely swing the baffle yourself, much less tip it and let gravity do it. I had to widen the mounting holes on the baffle to alleviate this problem. Then as we put the pan on, THREE holes did not line up with the motor. Then I turned and said "this is why I get the real name brands." It isn't over yet. When the motor was finally put in the car, we put the oil drain bolt in it stripped without even forcing it. The crap cast aluminum couldn't hold the threads well. The threads literally disintigrated.
