DjPantsSpecR »
https://forums.nicoclub.com/djpantsspecr-u24575.html
Fri Jun 10, 2005 9:19 pm
i cant say if it performs better, but i'm definately satisfied with mine. i use the apc knock-off greddy airinx style filter and it sits right where the filler neck for your washer fluid is. (you obviously have to relocate the battery, and the intake tube itself is a honda intake cut about eight inches mated to the stock rubber tube coming off the throttle body). this short ram intake produces a little more power up high than just a cone on the stock pipe, but it loses low end all over. not really recommended at all.
I removed my stock headlights and purchased standard rectangular foglamps. I then ripped out the H3 bulbs and replaced them with H4 headlight blubs. This allows you to cut out some of the area behind the headlight and actually use your "sleepy eye look" as a scoop like you always pretended to.
If you do this without building a cold air box the power gain is minimal, however once you build a box the horsepower gain from that alone is more than adding the intake in the first place. after running your car feel inside your cold air box and right outside of it, you'll see where all the extra power is coming from.
However, if you dont have 248/248 cams you might not have any business revving to where this intake has its most gains
