Nathan »
https://forums.nicoclub.com/nathan-u5605.html
Thu Dec 18, 2003 12:56 pm
Run a thicker gasket if you want, but realize that you are screwing up the quench areas they designed into that combustion chamber. You should be perfectly fine with a good factory thickness gasket and proper fuel/engine management.
