eBay FUCAS & RUCAS??
vstone48
Car: 1979 Pontiac Trans Am (Sold), 1990 Nissan 300zx, 2005 Chevrolet Silverado 1500 (Totaled)
HI, i was wondering if anyone has had experience with ebay FUCAS & RUCAS and was wondering if they would be okay to use. I have a feeling the answer is going to be No but im just curious here are a couple that i have found. Please let me know your opinions and if you think ill b ok with them. Thanks for the help
FUCAS http://cgi.ebay.com/ebaymotors/90-96-NI ... 0236331139
RUCAS http://cgi.ebay.com/ebaymotors/90-96-NI ... ccessories
BigTDogg (MA)
Car: 1990 Nissan 300ZX TT
I wouldn't, some people have without major issues, but I'd still recommend Powertrix over anything eBay. SPL still makes the best suspension parts for our cars, and they're a forum sponsor.
vstone48
Ok thank you ill check both out i just don't want to break the bank because then i might as well just get powertrix coilovers. And can anyone tell me if fucas and rucas will be enough if i lower it using eibach prokit or tein s springs? Thank you
robomatic12
Car: 1990 300ZX TT
If you are lowering with a spring kit and not coilovers, you should be fine with a 300degree camber kit up front and the stock rear camber adjustment bolt in the rear. The 300degree kit is a spacer that goes inbetween the stock front upper control arm and the body.
vstone48
even if im getting a 1.4 drop in the front?
robomatic12
Car: 1990 300ZX TT
Quoted from 300degree website:
"Relocating the upper link farther outboard from the factory position allows compensation for the additional negative camber shorter springs will cause. This kit is specifically engineered to compensate for EibachTM Pro 0.8" lowering springs but can be installed to compensate for up to 1.5" drop by an alignment specialist. It can also be used to compensate for the sag OEM springs have over time by an alignment specialist."
vstone48
Ok sweet that just saved me lots of money. Thank you
BigTDogg (MA)
vstone48 wrote:Ok sweet that just saved me lots of money. Thank you
Agreed, definitely worth it.
