evildky »
https://forums.nicoclub.com/evildky-u13100.html
Sun May 31, 2009 4:59 pm
the only similarity to the Z32 is the timing belt, it has to be changed or you risk tanking the engine
look for rust int he floor pans behind the seats where the rear subdrame bolts on, it's a common rust area
also lower rear quarters behind the wheels, and the lower portion fo the "A" pillars, and under the tool tray in the hatch
leaky power steerin is usually the result of boneheads adding PS fluid to the system (they use dextron type ATF same as the S130 and the Z32)
hardened cracked vac lines lead to hvac issues
and it's pretty obvious that car is suffering some severe clear coat failure, a total repaint is the only way to fix it
all things considdered I think they are more dependable than the Z32, less parts to fail
other than the paint it looks liek a decent car
