EBAY ca18de/ca18det water pump got me confused
Chinamandrift
Car: ca18det powered ae86
i thought the ca18et water pump are the only ones that fit ???....the ca18de are problematic right ?
heres a link ....
http://cgi.ebay.com/ebaymotors...QrdZ1
it says its oem for ca18de and ca18det.....how can i find out if its actually for a ca18det RWD??
driftin8ez
Car: 92 Coupe, Turbo Miata
Dude thanks for making a topic on this. I just got a brand new water pump for $20. You need to use the ca18et one if your going to use the stock WP pulley. Only 6 left better jump now!
http://cgi.ebay.com/ebaymotors...26380
Chinamandrift
sweet find .....beck arnley is not bad ......arnt those rebuilt or bran new ? ...........i know its better then the normal local parts store brands.....20 bucks i cant complain .......i think i will order one now
driftin8ez
well the auction states that they are brand new. I also cross checked the part# they give in the auction with parts stores and the wp is like $60 and it says it a brand new on not a reman. I think it's a pretty good deal.
ca18datsun510
Car: bmw 330i zhp, 91 infiniti m30, 89 240sx, 07 zx6r, 05 trx450r
see the little nub in the center?
on the fwd that nub, and the coresponding hole in the center of the wp pulley is smaller.
you can use it on rwd, but you need the fwd pulley, and you cant rock the clutch fan anymore.
DIng-KF
Car: Nissan CA18DET powered
Ok now i m confused . Is this a direct replacement for the RWD CA18DET or not ??
driftin8ez
The one i listed is a direct replacement for RWD CA engines. The ca18DE is fwd and that is what he i referring to with having to replace the pulley.
ca18datsun510
what makes you so sure?
that guys description has rwd and fwd/awd vehicle listed.
driftin8ez
ca18datsun510 wrote:what makes you so sure?
What makes me so sure? Two things in particular. 1) it the very first thing listed in the faq thread. Use the CA18ET W/P and stock pulley or change to the CA18DE W/P and Pulley. 2. Notice how out of all those applications the CA18DE isn't listed. Thats because it is different. Oh an thirdly every auto parts store lists diff. part numbers for the C18ET and the CA18DE. The diff. being the CA18ET has a huge clutch fan mounted on the W/P pulley and the CA18DE being fwd does not. Thats what makes me so sure that the one i posted will work on the CA18DET.
Here are some illustrations for you:
The correct CA18ET W/P (Pictured Below)
The incorrect CA18DE W/P notice how small the center hub is. That will incorrectly center the CA18DET W/P Pulley. (Pictured Below)
And one more... A Crappy cell phone shot of the stock W/P and Pulley that is on my car. (pictured Below)
Modified by driftin8ez at 6:50 PM 7/8/2007
ca18datsun510
driftin8ez wrote:blah blah blah blah
no no no, i know the difference between the rwd and fwd/awd pumps. notice i posted that answer about 3 posts before you.
i was asking how you know that guy is selling rwd ones. i didnt realize you posted your own link. i thought you were talking about the link the op put up, in which the seller lists the fwd and rwd cars.
my bad. glad you grasp it though.
r34 gtr
95.5 Audi URS6 Avant 5spd
03 BMW 330i ZHP 6spd
89 Nissan 240SX base CA18DET
just for the record, the det pulley works fine with the de pump as long as you dont use the clutch fan. i have been using an oem de pump with my det pulley for four years now and it hasnt missed a beat. before i got rid of the fan however, i couldnt make it a block without ruining the pump.
Chinamandrift
that leads to another question ........
what combination of water pumps and pulleys work on the ca18det RWD without the clutch fan???
r34 gtr
without the clutch fan i would say anything with a ca prefix.
Chinamandrift
so any CA pump ...with any CA pulley works... on a ca18det RWD with no clutch fan ???
driftin8ez
yep... your getting the hang of it now. However, I would just stick with the ca18et one.
driftin8ez
Oh it was all just a big misunderstanding then. LOL I was just really bored and decided i was going to make a mini write up on water pumps for the CA.
Chinamandrift
ok i just received the water pump for a "beck arnley ca18et water pump"
i looked on the housing and the water pump is from "GMB JAPAN"
how are GMB water pumps? anyone know anything about this ?
ca18datsun510
yeah beck arnly doesnt make parts, the relabel other companies stuff. but its usually pretty good stuff.
driftin8ez
Yep just got mine in. Stamped NPW but it definitely brand new and not a reman/
