boost_boy »
https://forums.nicoclub.com/boost-boy-u2853.html
Mon Aug 25, 2003 9:06 am
Like "Sean said" it will be a more of a parts motor. You can use the bottom end of this motor, but the head, both manifolds are a tad bit different and you would have to do some mods to be able to leave it like this. I suggest buying the engine and swapping the head for one off a U.S. spec pulsar and then you're in business. You could actually keep the turbo and manifold, but you will need to use the manifold off the U.S. pulsar as well.
