ebay 15mm wheel spacers...
jhuerto23
Car: 2006 Infiniti M45
I am looking for a set of 15mm wheel spacers. Is anybody riding on the ebay ones? They're about $68 a pair.
Wangtang408
Car: 2006 Infiniti M35
jhuerto23 wrote:I am looking for a set of 15mm wheel spacers. Is anybody riding on the ebay ones? They're about $68 a pair.
Get the black ones from ONEighty, they cost a little more $95/pair.
http://www.luceprodukt.com/e/oneighty_b ... _114_3.asp
jhuerto23
Thanks but I've already ordered a set.
Wangtang408
Cool man, don't forget to post pix!!
jhuerto23
Wangtang408 wrote:Cool man, don't forget to post pix!!
I will as soon as I get them in.
Arisotezza18
Car: 2008 M35s
Did you get the hubcentric ones with separate studs? I had the 20mm version on my old Maxima for 2 years with no problems. Removed them and sold them and I think the current owner is still running on them with no issues.
jhuerto23
Arisotezza18 wrote:Did you get the hubcentric ones with separate studs? I had the 20mm version on my old Maxima for 2 years with no problems. Removed them and sold them and I think the current owner is still running on them with no issues.
Yup, I got the hubcentric ones. Will take pics when they arrive.
CPJ LB
Car: 12 G37X Sedan- stealthy modded
14 Altima 2.5
08 Tahoe
06 M35 S (gone)
14 Versa 4dr (gone)
I looked at those back in the day...ended up going with H&R DRM's....15mm all around. I got the black set to match my cross drilled rotors with the black rotor hats....
I'm thinking of even going staggard with 20mm for the rears to give a 'more full' look :dblthumb:
jhuerto23
Just got them in and I ordered the wrong set. Smart of me. Anyway im going to exchange em for the right ones. The ones I accidentally ordered require me to remove my oem studs and replace it with longer studs. Will check back when I get the right ones
DaSerb
Car: '07 M45s
'16 CX9
jhuerto23 wrote:Just got them in and I ordered the wrong set. Smart of me. Anyway im going to exchange em for the right ones. The ones I accidentally ordered require me to remove my oem studs and replace it with longer studs. Will check back when I get the right ones
Shoot me a link for the correct ones....I am looking to do my front wheels in 15mm.
Thanks
Arisotezza18
Car: 2008 M35s
Those are the ones I had. If you are looking for the bolt on ones, you may need to cut your existing studs to clear your wheels...i.e. if your studs are longer than 15mm you will need to cut the excess off so your wheels sit flush with the spacer.
jhuerto23
Thanks
Here is the one I was suppose to order.
http://www.ebay.com/itm/HUBCENTRIC-BOLT ... 6a&vxp=mtr
jhuerto23
Thanks for the heads up on that. I will no longer be needing em since my wife just told me to replace the OEM with aftermarket wheels. So i'm just saving up for a new set of wheels now :dblthumb:
szh
Car: 2018 Tesla Model 3.
jhuerto23 wrote: since my wife just told me to replace the OEM with aftermarket wheels.
She is a smart lady! :yesnod
Replacing with the correct size wheels will be better than using spacers. IMHO.
Z
