slw240sx »
https://forums.nicoclub.com/slw240sx-u528.html
Sun Apr 06, 2003 4:00 pm
he means, what i was saying mount the ECu and wiring in the area above the steering column, and there are those five or so wires that need to be ran to the pass side for that clip over there, it should be good to go after that ! the hole would have to be the size of the other whole thats in the fire wall that the USDM harness goes into you could use that as a referance point!!!! am i correct at assuming thats what you were saying mad ??? IM me at Sidefxs1 if you want to ask anything or want to get some ideas to bounce around !!!
on the piggy back question, Emanage and SAFC would both have to be "hardwired" , as they have to be wired into the harness and the ECU remains intact.. on the question on which is better .. save the money a lil longer and buy the Emanage !!! they have more flexibilty then the AFC and you can control alot more things like bigger MAF , injectors and turbos !! it has more features and hooks up to a lap top which could be a bad or good thing, but why buy the sAFC and then few monthes later when going bigger you just have to sell it to get more money for that emanage of power FC you want to buy cause its more useful !! well hope this helps a bit ! JOn
