easy wiring question
NightKids2
Should be simple enough, just dont know if I need these two harnesses or not since the 8 steps page hasent worked in a month or two.
Do I need the KA Upper harnes for anything? Im having a hard time getting it through the firewall, and I was wondering if I could just cut it in the engine bay and pull it out both sides.
Also there is a harness still in my clip going from the fuse box along the front of the car and back along the left side. Im dont think I need this, but I just wanted to be sure.
accel junky
I dont think you need it. At least I havent used any part of it except for extending wires.
JonPowell
Car: Cars, Music, My family
You do NOT need the engine bay harness from the clip
You WILL need some plugs off the KA harness, but if you are having troubles getting it out, you will have even more troubles getting the RB harness back in.
Whenever I do this job, I always pull the dahs pad, dash reinforcement & blower motor box out of the vehicle for access...as hard as it sounds, its alot easier than fishing the harness out & back in.
dekand
Car: 1995 240sx SE
yeah exactly, pull those things out and the job is 50000x easier
