Easy Timing Chain Fix
deathkeeper
If this works, I will start a write-up of it tomorrow. It involves a very through cleaning of both chain tensioners. No removing of the guides (except the top one) will be necessary, as this can lead to rubbing a hole in the covers when the chain gets more slack. I also think I have found a way to remove the lower tensioner, without removing the lower timing cover.
