50Mustang wrote:Hi everyone,
I have a 1993 nissan maxima that has 80k on it. I have had has this car for 5 months now, and I must say, just like the 5.0 mustangs this car deff lives up to its reputation!
Ok, well being that I am a "FORD" guy I don't have all the info on nissan cars so I know you guys can help me.
Story short, I would like to know all the basic aftermarket ways to upgrade my nissan for better gas mileage and overall efficiency.
So far this is what I do know of, 1. Royal Purple oil and trans fluid, K&N air filter, NGK spark plugs and after market exhaust.
Ok so did I miss anything?
Probably the best "bang for the buck" bolt-on modification you can do for either the VG30E or the VE30DE engine is install a performance aftermarket Y-pipe.
It increases hp, which leads to better mpg.
They cost about $200 and if you worked on a Mustang in the past, you should be able to install it yourself. It's just a handful of bolts and a couple of gaskets. If you current Y-pipe is rusted on, most muffler shops only charge like $50 to install.
I did mine myself in a couple of hours, but I know a guy with a lift, which makes the job a lot easier.
The most common seller is:
http://www.warpspeedperformance.com
Personally, I have a y-pipe, intake, GReddy cat-back, underdrive pulley and an aluminum flywheel in my Maxima.
Up until last year, I could get 30 mpg on the freeway. This past fall, my retarded state (Oregon) mandated all gas be 10 percent ethanol, so my mpg has dropped by about 3-4 mpg.
