Easy question for those who know!
Texas240sx
I just completed swaping a 96' ka24de into my 89' hatch. Everything on the motor including the harness and computer is off a 96'. On the 96' harness near the computer there are about three other plugs smaller then the computer plug. I pluged in the computer and screwed on the plug. Right now my battery is at autozone getting charged before I can have a chance to crank it. Do those other plugs matter, cause I couldn't find anything near by that they would connect to. I couldn't find it using the search option. Thanks in advance! :D
96_S14_SE
Car: 96 S14 SE - 05 VW GTI 1.8t - 89 S13 coupe "gold on brown"
There are three 4 wire plugs correct? If so those are relays...
Edit: NM I think there is only one relay, I could look / check the fsm... How many wires are in each plug?
Texas240sx
Two of them look like small plug ins that are for accesories, but there is a miniature looking one that looks like the computer plug just smaller. Hopefully it will start with just the main computer being plugged. I work full time so I wont have a chance to crank it till saturday cause the shop it's in closes before I get out of work. Thanks!
96_S14_SE
Ill check it against mine and the fsm tommorow...
