easy one - installing bricks
Kalypso
the tech article is down.
there are five wires, two red, two black, one green.
the plug that goes to my headlights has only one red, two black and one green - should i solder the two reds on the bricks together?
Kalypso
i got it, the pink and black wire is for the high beam. the red is for the low. green for ground and black for negative. both of my blacks combine into the negative.
the bricks have three lights low, mid, and the high are in their own bulb.
my low and mids are on the indash switch, the highs are on the a seperate switch that the previous owner added.
this isnt very clearly explained but if these discoveries are even a little helpful and you need me to elaborate ill brake it all down for you,
[email protected]
peace.
