If your not putting a Z32 engine back in, then just cut the wiring, as the harness will be usless for a V8 engine. Unbolt trans and engine mounts.SYNASTR90ZX wrote:what is the easiest way to remove the motor and trans. from the top? drop the subframe? other ways? motor is locked up and gonna put a chevy v8 in it.
Why would you do that? That sounds like a great way to destroy something you may need, not to mention the fact that if his harness is in alright shape he could probably sell it for a bit.itsa300zx wrote: If your not putting a Z32 engine back in, then just cut the wiring, as the harness will be usless for a V8 engine. Unbolt trans and engine mounts.
