KADreams »
https://forums.nicoclub.com/kadreams-u27291.html
Wed Oct 19, 2005 1:00 pm
Don't waste your time with an engine swap. If you are going to spend time on the KA go ahead and build it up. If your want some N/A fun, get some titanium valve springs for the CA engine (they fit the KA), and retainers. Then get Crower to custom grind you a really agressive cam. Idle lope on the KA= the hotness. This along with an intake, header, exhaust, port/polish, ultralight flywheel, underdrive pulleys, and an SAFCII will yield very good results. The KA's stock fuel map runs way too rich, so you can fix that with the SAFC. Bump the base timing up a couple degrees also, but be sure to ALWAYS use premium fuel unless you want your ringlands/headgasket destroyed.
