Easiest way to replace exhaust manifold gasket on SR20DET?
keithdigital
My exhaust manifold gasket is leaking. Is it possible to just remove the nuts, pull the manifold out enough to squeeze the old gasket out and slip the new gasket in, or do I have to disconnect everything - Oil lines, Coolant lines, Downpipe, etc just to replace the head to manifold gasket? Thanks.
