heath when i took the lines out of my Q, they were sitll very flexible.....Q451990 wrote:Many members have glued the nut on with super glue to get it started. The "correct" way to do it (per Q45Tech) is to unbolt the a/c compressor and move it aside (the refrigerant lines flex) but I'm always scared to put tension on old rubber lines. Both alternator replacements I've done were with my dad (who conveniently has small hands).
Heath
I think I'd still put something under the compressor or bungee cord it up to take the tension off of the crimp fittings... I cringe every time I see brake calipers dangling from a car during a brake rotor replacement.... I mean how hard is it to get a few small bungee cords? And yes, I'm the guy that actually pulls on the plug rather than yanking the cord on the vacuum cleaner.DrewQ45 wrote:Loosen the bolts on the AC compressor allowing it to hang withh lines still attached.
Do people actually do this! OMG! Or am I naive? At least with an A/C unit you aren't tempting a brake failure.Q451990 wrote:... I cringe every time I see brake calipers dangling from a car during a brake rotor replacement....
Yes, that's a good thing to do. It's also good to put the car on stands instead of depending on the jack, disconnect battery cables while changing alternator, install new belts... look both ways when crossing the street.... the list can go on and on.... u get my drift. The words "hang free" were meant to convey an easier method and not so much to be taken literally... Common sense must always prevail.Q451990 wrote:
Heath
