easiest place to run wires from engine bay to inside car?
cyrus240sx
Car: 95 240sx with five lug swap, rims, suspension, I H E, remote start, too bad its auto
just as it says above, wondering where is the easiest place to run wires from battery etc. to inside the car... right now i have my wires running through the door jam which is ghetto and id like to make it look better
1991S13
Car: '91 240sx Coupe, '00 QX4 4x4, '02 Sentra Spec V
Shoulda searched, this question has been answered in the past.
I ran mine through the driver's side firewall where the cable to the hood popper goes through. There is a rubber boot around it you have to cut, then you can go over the steering column and back through the console.
FliMSiCaL
Car: 1989 240sx 1994 sentra limited edition
i have a 0 gauge power wire running thru the grommet on the suction refrigerant line for a/c. Just shove some of it off to the side and push thru, they allow for line flex in there.
