I was fully prepared to ride out the remaining few days left in the 2010 year from hell with no additional car issues, when BAM!! Last Saturday, my transmission would not shift to 3rd or 4th gear. The only issue I had with the trans during the time I owned this car was about a month ago, I had a minor hesitation starting off from a light, usually after driving the car on the highway. It was only once or twice during that month so I checked the fluid and looked and smelled fine. Since I was doing the Auto-rx treatment in the engine, I decided to do a treatment in the trans with the goal of draining the fluid and dropping the pan/filter in about 2-300 miles. Everything seemed to go smoothly -- I did not get another hesitation like before until I was coming home from the city. No CELs, no flashing O/D light, nothing. I pulled a ghost code of 0744 (torque converter clutch intermittent circuit) so I decided to drain the fluid and refill with fresh fluid. Drove the car and still same symtoms. Dropped it off to a "reputable" trans repair place and after two days, the owner tells me I have to do a complete rebuild at teh tune of $1800-2400 depending on what they find out once it's opened up. I asked if they dropped the pan and he said they did not get a chance to do that/ I said, how can you tell me what's wrong or if an internal part can be fixed if you don't do that? He said they didn't get a chance to do that, but they would od it this morning and let me know -- but from what they could tell, it needs a complete rebuild. At this point, I still ove my car and don't want to part with unless it simply becomes too cost prohibitive to keep fixing it.
So, here I am with a dilemma: put in a rebuilt trans for over $2K in a car that is worth maybe $6K on a good day, especially in this market or purchase a used unit with low miles and warranty and have a shop install it or buy and used unit and be crazy enough to attempt to install it myself. As one can imagine, I ruled out the first option because it doesn't make sense to do that when there are other things that need attention in the car. The second option is tempting, but since the car is going on 13 yrs old and there are brittle wiring harness plugs and rusted exhaust pieces that would have to removed, can I trust a company to successfully remove my old one and install the replacement unit without any electrical and/or exhaust issues?
So that brings me to my third option: pull the trans out myself and install the replacement unit. My question to all who have actually pulled an engine and/or trans out of a FGY33 model, is it easier to remove just the trans (knowing you have to pull the exhaust and wrestle the trans while lying on your back in the garage to get it out and then wrestle again to reinstall everything? Or, it is easier to leave the exhaust pipes alone, disconnect them from the headers/manifolds, drain the radiator and condensor, disconnect the PS pump from the engine and tie it out of the way and just pull everything in one shot? I have floor jack with a transmision adapter, so that is no problem. I also have a 3 ton cherry picker. The hood comes right off and from what I can tell, pulling it shouldn't be that hard, but I would prefer to hear from members who have actually done this. It may be a case where the engine and trans bolted together are too heavy and clumsy for one person to attempt this be them selves. Or maybe it's not too bad because both a cast aluminuim units. I have pulled many cast iron SBC engines and they can be a real pain to swing in and out of the car.
I can't believe I am dealing with this on top of all the crap I've repaired this year. It could have waiting 2 more weeks and we would at least be into 2011's budget. I guess there is no good time for this kind of issue to sprout up. Please let me know because I will be picking my car up from the shop this evening and setting a game plan of what to do next. So far, I have located a trans from a 1999 with 52K miles and a 2000 with 65K on it. I assume either one would fit exactly with no
plug or electrical problems. Please confirm that info as well.
Ted, Chicago
