encasemyheart »
https://forums.nicoclub.com/encasemyheart-u1676.html
Sun Apr 06, 2003 2:19 pm
It can be cheap at low low boost levels. I would go that route if I didn't want 400+whp.
A z31 turbo @ about 4psi or so would be very cheap. You would need a new fuel pump, adjustable fuel pressure regulator to turn up the fuel pressure, a short intake pipe if you use one at all, a pipe going from the turbo to throttle body very similar to the one already on the car that goes from the drivers side to the tb, 2 1/2" downpipe (custom) and a couple oil lines. The most expensive part would be the manifold. That would be it.
If I am correct in my thinking, you would need no fuel management at such a low psi, just a fuel pump and turn up the fuel pressure with a FPR. No intercooler at that psi.
It would be pretty simple. I suspect you could do all this for under $800 with mostly used/fabricated parts. It would cost less than a decent nitrous setup and give roughly similar gains, probably 35-40whp. Add an intercooler, exhaust, pulleys, fuel management with dyno tune etc. and you could have pretty decent power for such a small turbo.
Opinions?
